Saltar al contenido principal
Dell Inspiron 15-5547 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
Conclusión
Nicholas Nafziger
Miembro Desde 11/04/19
266 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G2, Harley Fall 2019 Miembro de IUPUI, Team S1-G2, Harley Fall 2019
IUPUI-HARLEY-F19S1G2
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,253
