Saltar al contenido principal
Dell Inspiron 15-5547 Fan Replacement
Qué necesitas
  1. Dell Inspiron 15-5547 Fan Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 15-5547 Fan Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 15-5547 Fan Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop on it's top and lay to a rest position.
    • Using the Phillips J0 screwdriver, remove the two indicated screws.
  2. Dell Inspiron 15-5547 Fan Replacement: paso 2, imagen 1 de 1
    • Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
    • Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
  3. Dell Inspiron 15-5547 Fan Replacement: paso 3, imagen 1 de 1
    • Use a Phillips J0 screwdriver in order to remove the screws indicated by the markers in the picture. It will be a total of 5 screws. Careful not to puncture the battery.
    • Carefully remove the battery by puling on the black tab.
  4. Dell Inspiron 15-5547 Fan Replacement, Fan: paso 4, imagen 1 de 2 Dell Inspiron 15-5547 Fan Replacement, Fan: paso 4, imagen 2 de 2
    • Start by removing the white ribbon cable. Lift up the black tab indicated by the red marker to disconnect the ribbon cable from the connector. Be careful while removing the ribbon cable, as it will possibly be taped to the fan.
  5. Dell Inspiron 15-5547 Fan Replacement: paso 5, imagen 1 de 1
    • After you have removed the ribbon cable, locate the screws indicated in the photo by the red markers (2 in total) and remove them with a Phillips J0 screwdriver.
  6. Dell Inspiron 15-5547 Fan Replacement: paso 6, imagen 1 de 1
    • Remove the fan cable, indicated by the red marker in the picture, by pulling it out from the connector. Be careful to pull it out by the plastic end instead of by the cable.
  7. Dell Inspiron 15-5547 Fan Replacement: paso 7, imagen 1 de 1
    • Once you have disconnected the fan from the motherboard, you may now remove the fan from the slot. Your laptop should now look similar to the picture in this step.
Conclusión
2 personas más completaron esta guía.
Un comentario
hola tengo un problema con mi pc, porque hay un cable que se calienta mucho y no se a que se debe.
luis_gon1313 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 1,340
