Saltar al contenido principal
Dell Inspiron 15-3543 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement: paso 2, imagen 2 de 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-3543 Keyboard Replacement: paso 3, imagen 2 de 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Conclusión
2 personas más completaron esta guía.
Un comentario
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 25
Ultimos 30 días: 32
Todo El Tiempo: 1,190
