Saltar al contenido principal
Dell Inspiron 15-3542 LCD Screen Replacement
Qué necesitas
  1. Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Power off the laptop.
    • Flip the laptop over so the bottom is facing up.
    • Slide the right button to the unlock symbol.
    • Slide the left button to the other unlock symbol.
    • While holding the left button, use your right finger to raise the battery up from the laptop.
  2. Dell Inspiron 15-3542 LCD Screen Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over so the top is facing up and open the laptop.
    • Using both hands, unsnap the tabs around the perimeter of the bezel and remove it from the laptop.
  3. Dell Inspiron 15-3542 LCD Screen Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Remove the four screws from the corners of the LCD using a Phillips screwdriver.
    • Lift the screen up and place it on the keyboard.
  4. Dell Inspiron 15-3542 LCD Screen Replacement: paso 4, imagen 1 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 4, imagen 2 de 3 Dell Inspiron 15-3542 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Gently peel off the yellow clear tape securing the video connector.
    • Use an opening tool to flip open the video connector bracket.
    • Make sure not to force the video cable when removing it from the connector bracket.
    • Disconnect the cable from the LCD screen and remove the LCD from the laptop.
Conclusión
Una persona más ha completado esta guía.
Najeemdeen Lamidi
Miembro Desde 09/19/20
130 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 1,077
