Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dell Inspiron 15-3531 Motherboard Replacement
Qué necesitas
  1. Dell Inspiron 15-3531 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  2. Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: paso 2, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel open with the spudger.
    Pregunta a FixBot
    Agregar Comentario
  3. Dell Inspiron 15-3531 Motherboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the memory card by pulling apart the latches holding it in place.
    Pregunta a FixBot
    Agregar Comentario
  4. Dell Inspiron 15-3531 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the nine 8.65mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    • Remove the four 1.22 mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  5. Dell Inspiron 15-3531 Motherboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 5, imagen 3 de 3
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard using a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting out the keyboard because there is a cable connecting it to the laptop.
    Pregunta a FixBot
    Agregar Comentario
  6. Dell Inspiron 15-3531 Motherboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
    Pregunta a FixBot
    Agregar Comentario
  7. Dell Inspiron 15-3531 Motherboard Replacement: paso 7, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 7, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 7, imagen 3 de 3
    • Disengage both antenna (black and white) cables by lifting them up using the spudger.
    • Unscrew the one 8.65 mm screw holding the wireless card.
    • Remove the wireless card.
    Pregunta a FixBot
    Agregar Comentario
  8. Dell Inspiron 15-3531 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron 15-3531 Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift the locking tab with the spudger and pull the cable form the locking tab.
    • Repeat with the second locking tab.
    Pregunta a FixBot
    Agregar Comentario
  9. Dell Inspiron 15-3531 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the four 8.65 mm screws underneath the keyboard plate.
    • Remove the three 1.22 mm small screws underneath the keyboard plate.
    Pregunta a FixBot
    Agregar Comentario
  10. Dell Inspiron 15-3531 Motherboard Replacement: paso 10, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 10, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 10, imagen 3 de 3
    • Separate the palmrest from the base of the laptop using the spudger to loosen the palmrest along the edges.
    • Make sure to remove all the screws, especially the inconspicuous 8.65 mm screw next to the hard drive.
    Pregunta a FixBot
    Agregar Comentario
  11. Dell Inspiron 15-3531 Motherboard Replacement: paso 11, imagen 1 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 11, imagen 2 de 3 Dell Inspiron 15-3531 Motherboard Replacement: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the cables on the upper left side of the laptop using flat tweezers.
    • Remove the cable from the upper right hand corner.
    Pregunta a FixBot
    Agregar Comentario
  12. Dell Inspiron 15-3531 Motherboard Replacement: paso 12, imagen 1 de 2 Dell Inspiron 15-3531 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the speaker cable.
    • Remove cable on the right-hand side.
    Pregunta a FixBot
    Agregar Comentario
  13. Dell Inspiron 15-3531 Motherboard Replacement: paso 13, imagen 1 de 1
    • Unscrew the one 8.65 mm screw holding the motherboard in place with a PH0 size head screwdriver.
    • Remove the motherboard.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Kody Dahlke
Miembro Desde 02/15/18
742 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
Miembros de 5
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,884
