Saltar al contenido principal
Dell Inspiron 15-3531 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 15-3531 Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: paso 2, imagen 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement, Hard Drive: paso 2, imagen 3 de 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel from the laptop using the spudger.
  3. Dell Inspiron 15-3531 Hard Drive Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-3531 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Lift the access panel away from the laptop to reveal the hard drive on the left.
    • Remove the two 8.65 mm screws on the left side of the hard drive using the PH0 head screwdriver.
    • There is a plastic tab beneath the hard drive.
  4. Dell Inspiron 15-3531 Hard Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 15-3531 Hard Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 15-3531 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Push the hard drive to the left to release it and use the tab to pull it free from the laptop. The hard drive is in a caddy.
    • Remove the two 1.22 mm screws holding the hard drive in the caddy with the PH0 head screwdriver.
Conclusión
Kody Dahlke
Miembro Desde 02/15/18
742 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 21
Ultimos 30 días: 30
Todo El Tiempo: 1,115
