Saltar al contenido principal
Dell Inspiron 15-3521 RAM Replacement
Qué necesitas
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: paso 1, imagen 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: paso 1, imagen 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: paso 1, imagen 3 de 3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: paso 2, imagen 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: paso 2, imagen 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: paso 2, imagen 3 de 3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: paso 3, imagen 3 de 3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
Conclusión
7 personas más completaron esta guía.
Andrew Dippre
Miembro Desde 10/13/14
2,902 Reputación
7 Guías creadas
Equipo
Clemson, Team 3-1, Benson Fall 2014 Miembro de Clemson, Team 3-1, Benson Fall 2014
CLEM-BENSON-F14S3G1
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 6,094
