Saltar al contenido principal
Dell Inspiron 15 Optical Drive Replacement
Qué necesitas
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 15 Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
Conclusión
3 personas más completaron esta guía.
Edward Pacheco
Miembro Desde 03/06/16
845 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 17
Ultimos 30 días: 20
Todo El Tiempo: 4,836
