Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Remove the two screws from the computer base.
    • Remove the two screws from the computer base.
  2. Slide the hard drive to the right to disconnect it from the connector on the system board.
    • Slide the hard drive to the right to disconnect it from the connector on the system board.
  3. Lift the hard drive out of the computer base.
    • Lift the hard drive out of the computer base.
  4. Place the NEW hard drive on the computer base.
    • Place the NEW hard drive on the computer base.
  5. Push the hard drive towards the left to connect it to the connector on the system board.
    • Push the hard drive towards the left to connect it to the connector on the system board.
  6. Replace the two screws to the computer base.
    • Replace the two screws to the computer base.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,933 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 10
Todo El Tiempo: 157
