Saltar al contenido principal
Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
Qué necesitas
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: paso 1, imagen 1 de 2 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: paso 1, imagen 2 de 2
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 2, imagen 3 de 3
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 3, imagen 3 de 3
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 4, imagen 3 de 3
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: paso 5, imagen 3 de 3
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 3,400
