Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
  2. Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  3. Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
    • Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
  4. Open the palm-rest assembly.
    • Open the palm-rest assembly.
  5. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  6. Lift the palm-rest assembly at an angle off the display assembly. Lift the palm-rest assembly at an angle off the display assembly.
    • Lift the palm-rest assembly at an angle off the display assembly.
  7. Place the display assembly on a clean, flat surface.
    • Place the display assembly on a clean, flat surface.
  8. Place the NEW display assembly on the palm-rest assembly.
    • Place the NEW display assembly on the palm-rest assembly.
  9. Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Replace the screws that secure the display hinges to the palm-rest assembly.
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  11. Route the display cable through its routing guides on the palm-rest assembly.
    • Route the display cable through its routing guides on the palm-rest assembly.
  12. Route the antenna cables through its routing guides on the palm-rest assembly.
    • Route the antenna cables through its routing guides on the palm-rest assembly.
    • Close the display and turn the computer over.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
71,146 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 16
Todo El Tiempo: 262
