Saltar al contenido principal
Dell Inspiron 15 7579 RAM (Memory) Replacement
Qué necesitas
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 2, imagen 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): paso 3, imagen 1 de 1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 4, imagen 1 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 4, imagen 2 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 5, imagen 3 de 3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 6, imagen 1 de 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: paso 6, imagen 2 de 2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Conclusión
Inaki Madrigal
Miembro Desde 04/23/18
760 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S24-G9, Maness Spring 2018 Miembro de Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 711
