Saltar al contenido principal
Dell Inspiron 15 7579 Fan Replacement
Qué necesitas
  1. Dell Inspiron 15 7579 Fan Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Fan Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15 7579 Fan Replacement: paso 2, imagen 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Fan Replacement, Fan: paso 3, imagen 1 de 2 Dell Inspiron 15 7579 Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Fan Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 7579 Fan Replacement: paso 4, imagen 2 de 2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Fan Replacement: paso 5, imagen 1 de 1
    • Carefully lift the fan out of the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 225
