Saltar al contenido principal
Dell Inspiron 15 5584 SSD Replacement
Qué necesitas
  1. Dell Inspiron 15 5584 SSD Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 SSD Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15 5584 SSD Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15 5584 SSD Replacement: paso 2, imagen 3 de 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 SSD Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15 5584 SSD Replacement: paso 3, imagen 2 de 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 SSD Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 5584 SSD Replacement: paso 4, imagen 2 de 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 SSD Replacement, Battery: paso 5, imagen 1 de 2 Dell Inspiron 15 5584 SSD Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 SSD Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15 5584 SSD Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15 5584 SSD Replacement: paso 6, imagen 3 de 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 SSD Replacement, SSD: paso 7, imagen 1 de 3 Dell Inspiron 15 5584 SSD Replacement, SSD: paso 7, imagen 2 de 3 Dell Inspiron 15 5584 SSD Replacement, SSD: paso 7, imagen 3 de 3
    • Remove the single 3 mm screw from the SSD cover with a JIS #0 screwdriver.
    • Carefully lift off the SSD cover and put to the side.
  8. Dell Inspiron 15 5584 SSD Replacement: paso 8, imagen 1 de 2 Dell Inspiron 15 5584 SSD Replacement: paso 8, imagen 2 de 2
    • Disconnect the SSD cable from the motherboard port.
    • Remove the SSD and place it off to the side.
Conclusión
Sam Vorn
Miembro Desde 03/29/22
977 Reputación
9 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Miembro de UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 839
