Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer. CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
    • Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
  3. Note the hard-drive cable routing and remove the cable from the routing guides.
    • Note the hard-drive cable routing and remove the cable from the routing guides.
  4. Remove the three screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Remove the three screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  5. Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  6. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
  7. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  8. Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Lift the hard drive off the hard-drive bracket. Lift the hard drive off the hard-drive bracket.
    • Lift the hard drive off the hard-drive bracket.
  10. Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  11. Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  12. Connect the interposer to the hard-drive assembly.
    • Connect the interposer to the hard-drive assembly.
  13. Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  14. Replace the screws three (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
    • Replace the screws three (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  15. Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
    • Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
  16. Connect the hard-drive cable to the system board.
    • Connect the hard-drive cable to the system board.
  17. Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
    • Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
Linea de Meta
Una persona más ha completado esta guía.
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 43
Todo El Tiempo: 497
