Saltar al contenido principal
Dell Inspiron 15 5577 Gaming Laptop RAM Replacement
Qué necesitas
  1. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: paso 1, imagen 1 de 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Before working inside your laptop, read the safety information that came with the laptop and follow the steps "When Working Inside Your Device."
    • Shut down the device by holding down the power button for a few seconds.
    • Remove the power cable from the device.
  2. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 2, imagen 3 de 3
    • Flip the device over so that the bottom is facing up.
    • With a Phillips #00 screwdriver, loosen the screw located at the top of the base panel.
    • Loosen the screw so that it is removed from the insert but is still connected to the base panel. This will create an opening for the next step.
  3. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 3, imagen 3 de 3
    • Use a spudger to gently pry up the top of the base panel until it pops loose.
    • Continue along the edges.
    • The corners may require a bit more force to pop loose, but refrain from applying excessive force.
  4. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 4, imagen 2 de 2
    • Remove the laptop base panel.
  5. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 5, imagen 3 de 3
    • Use your fingertips to spread apart the securing-clips on both ends of the slot until the RAM stick pops up.
    • Remove the RAM stick.
  6. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 6, imagen 3 de 3
    • Align the notch of the new RAM stick with the tab in the slot.
    • Firmly slide the new RAM in the slot at an angle.
    • Press down until both secure-clips click into place.
    • If you do not hear the click, remove and reinstall the RAM stick again.
  7. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 7, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 7, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: paso 7, imagen 3 de 3
    • Replace the base panel.
    • Firmly press on the edges of the base panel until it is clicked in.
    • Tighten the screw at the top of the base panel.
Linea de Meta
Una persona más ha completado esta guía.
John Lacadin
Miembro Desde 09/17/20
172 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 1,133
