Saltar al contenido principal
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
Qué necesitas
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: paso 1, imagen 1 de 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 2, imagen 1 de 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 3, imagen 1 de 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 4, imagen 1 de 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 6, imagen 1 de 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: paso 7, imagen 1 de 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
Conclusión
[deleted]
Miembro Desde 10/31/19
346 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 37
Todo El Tiempo: 818
