Saltar al contenido principal
Dell Inspiron 15 5577 Gaming Fans Replacement
Qué necesitas
  1. Dell Inspiron 15 5577 Gaming Fans Replacement, Fans: paso 1, imagen 1 de 1
    • Unscrew the base cover plate to locate the gaming fan.
  2. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 2, imagen 1 de 1
    • Remove the base cover.
  3. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 3, imagen 1 de 1
    • Gently tug on the battery cable in order to disconnect it from the motherboard.
  4. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 4, imagen 1 de 1
    • Loosen the screws that secure the battery in place.
  5. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 5, imagen 1 de 1
    • Carefully pull the battery out of the laptop.
  6. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 6, imagen 1 de 1
    • Remove the cable above the hard drive.
  7. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 7, imagen 1 de 1
    • Loosen the screws that secure the hard drive.
  8. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 8, imagen 1 de 1
    • Carefully remove the hard drive.
  9. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 9, imagen 1 de 3 Dell Inspiron 15 5577 Gaming Fans Replacement: paso 9, imagen 2 de 3 Dell Inspiron 15 5577 Gaming Fans Replacement: paso 9, imagen 3 de 3
    • Flip the laptop over and open the lid.
    • Remove the palm rest.
  10. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 10, imagen 1 de 1
    • Carefully unsecure the rest of the shell on the base of the computer.
  11. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 11, imagen 1 de 1
    • Remove the keyboard.
  12. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 12, imagen 1 de 1
    • Loosen the screws securing the metal plate and contents of the base.
  13. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 13, imagen 1 de 1
    • Remove the plate.
  14. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 14, imagen 1 de 1
    • Unscrew and remove the first fan from the base of the laptop.
  15. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 15, imagen 1 de 1
    • Remove the fan's cable from the board.
  16. Dell Inspiron 15 5577 Gaming Fans Replacement: paso 16, imagen 1 de 1
    • Repeat steps 14 and 15 for the remaining fan.
Conclusión
3 personas más completaron esta guía.
Julia Cabral
Miembro Desde 10/31/19
379 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 39
Todo El Tiempo: 2,183
