Saltar al contenido principal
Dell Inspiron 15 5565 IO Board Replacement
Qué necesitas
  1. Dell Inspiron 15 5565 IO Board Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15 5565 IO Board Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15 5565 IO Board Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15 5565 IO Board Replacement: paso 2, imagen 3 de 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15 5565 IO Board Replacement, Back Cover: paso 3, imagen 1 de 2 Dell Inspiron 15 5565 IO Board Replacement, Back Cover: paso 3, imagen 2 de 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15 5565 IO Board Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 5565 IO Board Replacement: paso 4, imagen 2 de 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15 5565 IO Board Replacement, IO Board: paso 5, imagen 1 de 3 Dell Inspiron 15 5565 IO Board Replacement, IO Board: paso 5, imagen 2 de 3 Dell Inspiron 15 5565 IO Board Replacement, IO Board: paso 5, imagen 3 de 3
    • Lift up the cover to pull out the cable.
  6. Dell Inspiron 15 5565 IO Board Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15 5565 IO Board Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15 5565 IO Board Replacement: paso 6, imagen 3 de 3
    • Remove the single 5 mm screw from the main part of the IO board using a Phillips #00 screwdriver.
    • Remove the IO board from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 98
