Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  2. Note the display cable routing and remove the cable from its routing guides.
    • Note the display cable routing and remove the cable from its routing guides.
  3. Lift the latch and disconnect the display cable from the system board. Lift the latch and disconnect the display cable from the system board.
    • Lift the latch and disconnect the display cable from the system board.
  4. Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Open the display hinges.
    • Open the display hinges.
  6. Lift the palm rest and keyboard assembly off the display assembly.
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Place the palm rest and keyboard assembly on the NEW display assembly.
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Route the display cable through the routing guides on the palm rest and keyboard.
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Slide the display cable to the connector on the system board and close the latch to secure the cable. Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,933 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 9
Todo El Tiempo: 153
