Saltar al contenido principal
Dell Inspiron 15 3593 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 15 3593 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15 3593 Battery Replacement: paso 2, imagen 2 de 2
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15 3593 Battery Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15 3593 Battery Replacement: paso 3, imagen 3 de 3
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 3593 Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: paso 5, imagen 1 de 1
    • Lift the battery out carefully and put the new battery in.
Conclusión
Reassemble the computer by following
the above steps in reversed order.
2 personas más completaron esta guía.
Abdul Obaid
Miembro Desde 01/13/22
169 Reputación
1 Guía escrita
Equipo
2 comentarios
not all of the steps
there is somethings missing
aaaa2020 - Contestar
So where is the rest of the story?
Jeanette Martinez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 89
Todo El Tiempo: 2,789
