Saltar al contenido principal
Dell Inspiron 15 3541 Battery Replacement
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 15 3541 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: paso 2, imagen 1 de 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
Conclusión
3 personas más completaron esta guía.
Allison
Miembro Desde 03/04/16
547 Reputación
2 Guías creadas
Equipo
2 comentarios
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - Contestar
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,615
