Introducción
The motherboard for this computer allows all of the hardware of the computer to communicate. If this becomes damaged, major problems will occur.
Qué necesitas
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
Lift up the bottom of the hard drive which is located at the bottom of the laptop.
Gently pull the drive out at an angle using your fingers.
Gently pull the the blue ribbon upwards to disconnect the computer from the motherboard.
2 personas más completaron esta guía.
