Saltar al contenido principal
Dell Inspiron 14z-5423 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: paso 1, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: paso 1, imagen 2 de 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: paso 2, imagen 1 de 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement: paso 3, imagen 2 de 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement: paso 4, imagen 2 de 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: paso 6, imagen 1 de 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: paso 6, imagen 2 de 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: paso 6, imagen 3 de 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: paso 7, imagen 1 de 1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement: paso 8, imagen 2 de 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron 14z-5423 Keyboard Replacement: paso 9, imagen 2 de 2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: paso 10, imagen 1 de 3 Dell Inspiron 14z-5423 Keyboard Replacement: paso 10, imagen 2 de 3 Dell Inspiron 14z-5423 Keyboard Replacement: paso 10, imagen 3 de 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Conclusión
2 personas más completaron esta guía.
Marisol
Miembro Desde 09/12/16
623 Reputación
4 Guías creadas
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2016 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,497
