Introducción
The palm rest assembly is the casing surrounding the keyboard. This may become worn down, scratched, or cracked over time. Replacement of this part is mainly cosmetic but may enhance the user experience.
Qué necesitas
Slide the CD/DVD drive on the side of the laptop out using your fingers.
Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
Lift the plastic yellow flap on the system board.
Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
