Saltar al contenido principal
Dell Inspiron 14z Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: paso 2, imagen 1 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 2, imagen 2 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: paso 3, imagen 1 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 3, imagen 2 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 3, imagen 3 de 3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 14z Hard Drive Replacement: paso 4, imagen 3 de 3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: paso 5, imagen 1 de 1
    • The hard drive is now removed from the caddy and the replacement can be installed.
Conclusión
2 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
784,339 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
560 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 12,785
