Introducción
Pretty straight forward repair. Biggest issue I found while doing it, is that spring clip that holds the screw to the cover. It does have a tendency to come off during the removal of the cover. It could theoretical fall into the opening of the drive bay. Make sure you know where it is so that it does not get lost.
Here is a Dell Inspiron 14z N411z with a defective hard drive. On the back side is only one cover for the hard drive as well as the memory module. Remove the Phillips screw on the bottom right corner of the cover.
  • Here is a Dell Inspiron 14z N411z with a defective hard drive.
  • On the back side is only one cover for the hard drive as well as the memory module.
  • Remove the Phillips screw on the bottom right corner of the cover.
Agregar Comentario
Use a plastic opening tool to unsnap the cover from the back case. Move the tool gently along the corner of the cover. The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  • Use a plastic opening tool to unsnap the cover from the back case.
  • Move the tool gently along the corner of the cover.
  • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
Agregar Comentario
With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket. Slide the hard drive to the opposite end of the connector. This will free the connection. Slide the hard drive to the opposite end of the connector. This will free the connection.
  • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
  • Slide the hard drive to the opposite end of the connector. This will free the connection.
Agregar Comentario
Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer. Remove the two Phillips screws on the right side, and the two Phillips screws on the left side.
  • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
  • Remove the two Phillips screws on the right side,
  • and the two Phillips screws on the left side.
Agregar Comentario
The hard drive is now removed from the caddy and the replacement can be installed.
  • The hard drive is now removed from the caddy and the replacement can be installed.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
oldturkey03
Miembro Desde 29/09/10
523,314 Reputación
120 Guías creadas
Equipo
OTS Miembro de OTS
Business
1 Miembro
120 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 16
Todo El Tiempo: 12,295
