Saltar al contenido principal
Dell Inspiron 14R-5421 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14R-5421 Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: paso 4, imagen 1 de 1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Conclusión
Jared paiva
Miembro Desde 03/27/18
489 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 571
