Introducción
This is a process that requires going into the Dell Inspiron 1440 laptop. When completing this step, you will need a screwdriver and a prying tool. When trying to pull up the grey cover, make sure to work around bit by bit will prying to make sure that it is loose on all sides before trying to pull it up.
Qué necesitas
Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
Once it pops out, pull it off.
