Saltar al contenido principal
Dell Inspiron 14-5447 Fan Replacement
Qué necesitas
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 2, imagen 2 de 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: paso 3, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 3, imagen 2 de 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: paso 4, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 4, imagen 2 de 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: paso 5, imagen 1 de 1
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: paso 6, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 6, imagen 2 de 2
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: paso 7, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 7, imagen 2 de 2
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: paso 8, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 8, imagen 2 de 2
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: paso 9, imagen 1 de 2 Dell Inspiron 14-5447 Fan Replacement: paso 9, imagen 2 de 2
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: paso 10, imagen 1 de 1
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 806
