Saltar al contenido principal
Dell Inspiron 14-5447 Battery Replacement
Qué necesitas
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 14-5447 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: paso 3, imagen 1 de 2 Dell Inspiron 14-5447 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 14-5447 Battery Replacement: paso 4, imagen 2 de 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 3,022
