Saltar al contenido principal
Dell Inspiron 14-5415 Hard Drive Replacement
Qué necesitas
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
Conclusión
Ilana Ek-Adler
Miembro Desde 02/09/23
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 232
