Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Slide the hard-drive assembly to disconnect it from the connector on the system board.
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Lift the hard-drive assembly away from the system board.
    • Lift the hard-drive assembly away from the system board.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  6. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  7. Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  8. Slide and push the hard-drive assembly to connect it to connector on the system board.
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  9. Replace the two screws that secure the hard-drive assembly to the system board.
    • Replace the two screws that secure the hard-drive assembly to the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 17
