Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the solid-state drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  2. Slide and remove the solid-state drive from the solid-state drive slot.
    • Slide and remove the solid-state drive from the solid-state drive slot.
  3. Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
    • Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
  4. Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
    • Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
  5. Replace the screw (M2x3) that secures the solid-state drive to the computer base.
    • Replace the screw (M2x3) that secures the solid-state drive to the computer base.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,933 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 15
