Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • CAUTION: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
    • Using a plastic scribe, lift the latch and use the pull tab to disconnect the hard-drive cable from the system board.
  2. Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
    • Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  3. Lift the hard-drive assembly, along with its cable, off the computer base.
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Remove the hard-drive bracket off the hard drive.
    • Remove the hard-drive bracket off the hard drive.
  8. Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  9. Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Connect the interposer to the hard drive.
    • Connect the interposer to the hard drive.
  11. Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
    • Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  13. Connect the hard-drive cable to the system board.
    • Connect the hard-drive cable to the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 17
