Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your  computer, follow the instructions in After Working Inside Your Computer.
  2. Peel off the camera cable from the computer base.
    • Peel off the camera cable from the computer base.
  3. Remove the antenna cables from the routing guides on the computer  base.
    • Remove the antenna cables from the routing guides on the computer base.
  4. Remove the screw (M2x3) that secures the display-cable bracket to the  system board.
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Lift the display-cable bracket off the system board.
    • Lift the display-cable bracket off the system board.
  6. Using the pull-tab, disconnect the display cable from the system board.
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Peel off the display cable from the computer base.
    • Peel off the display cable from the computer base.
  8. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  9. Remove the two screws (M2x3) that secure the display assembly to the  computer base.
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  10. Remove the two screws (M2.5x5) that secure the display assembly to the  computer base.
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  11. Turn the computer over and open the display.
    • Turn the computer over and open the display.
  12. Remove the two screws (M2.5x5) that secure the display assembly to the  computer base.
  13. Lift the display assembly off the computer base.
    • Lift the display assembly off the computer base.
  14. Align the screw holes on the NEW display assembly with the screw holes on  the computer base.
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  15. Replace the two screws (M2.5x5) that secure the display assembly to the  computer base.
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  16. Close the display and turn the computer over.
    • Close the display and turn the computer over.
  17. Replace the two screws (M2x3) that secure the display assembly to the  computer base.
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  18. Adhere the display cable and the camera cable to the computer base.
    • Adhere the display cable and the camera cable to the computer base.
  19. Connect the display cable and camera cable to the system board.
    • Connect the display cable and camera cable to the system board.
  20. Align the screw hole on the display-cable bracket with the screw hole on  the system board.
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  21. Replace the screw (M2x3) that secures the display cable bracket to the  system board.
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 30
