Saltar al contenido principal
Dell Inspiron 14 7460 Battery Replacement
Qué necesitas
  1. Dell Inspiron 14 7460 Battery Replacement, Disconnecting the Battery Cable: paso 1, imagen 1 de 1
  2. Dell Inspiron 14 7460 Battery Replacement, Remove the Screws: paso 2, imagen 1 de 1
    • Remove the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  3. Dell Inspiron 14 7460 Battery Replacement, Lifting the Battery: paso 3, imagen 1 de 1
    • Lift the battery off the palm rest and keyboard assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 7460 Battery Replacement, Align the Screw Holes: paso 5, imagen 1 de 1
    • Align the screw holes on the NEW battery with the screw holes on the palm rest and keyboard assembly.
  5. Dell Inspiron 14 7460 Battery Replacement, Replace the Screws: paso 6, imagen 1 de 1
    • Replace the four screws (M2x3) that secure the battery to the palm rest and keyboard assembly.
  6. Dell Inspiron 14 7460 Battery Replacement, Connecting the Battery Cable: paso 7, imagen 1 de 1
    • Connect the battery cable to the system board.
Conclusión
Una persona más ha completado esta guía.
Terrence15
Miembro Desde 12/18/17
79,131 Reputación
441 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
42 Miembros
1,986 Guías creadas
Un comentario
Grounding the System Board is required after removing battery?
Nemo Einstein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 44
Todo El Tiempo: 6,340
