Introducción
How to remove and replace the Hard-Drive.
Partes
No se requieren partes.
  1. Remove the screws that secure the hard-drive assembly to the computer base.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Open the latch and disconnect the hard-drive cable from the system board.
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Lift the hard-drive assembly off the computer base.
    • Lift the hard-drive assembly off the computer base.
  4. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  7. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  8. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  9. Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  10. Replace the screws that secure the hard-drive bracket to the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  11. Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Slide the hard-drive cable into the system board and close the latch to secure the cable.
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Linea de Meta
Una persona más ha completado esta guía.
darrius
Miembro Desde 26/03/18
5,072 Reputación
30 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 28
