Saltar al contenido principal
Introducción
How To Remove And Replace The Hard-Drive
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Lift the hard-drive assembly along with its cable off the palm-rest assembly.
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the hard-drive assembly off the hard-drive bracket.
    • Lift the hard-drive assembly off the hard-drive bracket.
  7. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  8. Connect the interposer to the NEW hard drive
    • Connect the interposer to the NEW hard drive
  9. Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  10. Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  11. Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Conclusión
darrius
Miembro Desde 26/03/18
5,072 Reputación
30 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 38
Todo El Tiempo: 501
