Saltar al contenido principal
Dell Inspiron 14 3467 Base Cover Replacement
Qué necesitas
  1. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: paso 1, imagen 1 de 1
  2. Dell Inspiron 14 3467 Base Cover Replacement, Remove the Screws: paso 2, imagen 1 de 1
    • Remove the eight screws that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: paso 3, imagen 1 de 1
    • Remove the two screws that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3467 Base Cover Replacement, Removing the screws: paso 4, imagen 1 de 1
    • Remove the three screws that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer over: paso 5, imagen 1 de 1
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: paso 6, imagen 1 de 1
  7. Dell Inspiron 14 3467 Base Cover Replacement, Disconnecting the Optical-Drive Cable: paso 7, imagen 1 de 1
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer Over: paso 8, imagen 1 de 1
    • Close the display, and turn the computer over
  9. Dell Inspiron 14 3467 Base Cover Replacement, Prying the Base Cover: paso 9, imagen 1 de 1
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3467 Base Cover Replacement, Lifting the Base Cover: paso 10, imagen 1 de 1
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3467 Base Cover Replacement, Release the Optical-Drive Interposer: paso 11, imagen 1 de 1
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive: paso 12, imagen 1 de 1
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Base Cover: paso 13, imagen 1 de 1
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Tabs: paso 14, imagen 1 de 1
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive Cable: paso 15, imagen 1 de 1
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Screws: paso 16, imagen 1 de 1
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: paso 17, imagen 1 de 1
    • Close the display, and turn the computer over.
  18. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: paso 18, imagen 1 de 1
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: paso 19, imagen 1 de 1
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: paso 20, imagen 1 de 1
    • Replace the eight screws that secure the base cover to the palm-rest assembly.
Linea de Meta
Una persona más ha completado esta guía.
darrius
Miembro Desde 03/26/18
5,213 Reputación
30 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
42 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,975
