Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. Follow the instructions in "Before You Begin".
    • Follow the instructions in "Before You Begin".
    • Remove the two screws that secure the display panel to the chassis.
  2. Turn the computer over and open  the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  3. Make a note of the routing of the Mini-Card antenna cables and the  display cables. Remove the cables from the routing guides.
    • Make a note of the routing of the Mini-Card antenna cables and the display cables. Remove the cables from the routing guides.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the two screws (one on each side) that secure the display assembly  to the computer base.
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Make a note of the cable routing and disconnect the display cable and the  wireless card antenna cables from the connectors on the Mini-Card.
    • Make a note of the cable routing and disconnect the display cable and the wireless card antenna cables from the connectors on the Mini-Card.
  7. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  8. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base. Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  9. Route the Mini-Card antenna cables and the display cable through the slot  on the computer base.
    • Route the Mini-Card antenna cables and the display cable through the slot on the computer base.
  10. Connect the display cable to the  connector on the system board.
    • Connect the display cable to the connector on the system board.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 40
