Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. Follow the instructions in Before You Begin.
    • Follow the instructions in Before You Begin.
    • Turn the computer over.
    • Disconnect the Mini-Card antenna cables from the computer base.
  2. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  3. Disconnect the display cable and the camera cable from their connectors on the system board.
    • Disconnect the display cable and the camera cable from their connectors on the system board.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
    • Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  6. Remove the six screws (three on each side) that secure the display assembly to the computer base.
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  7. Lift and remove the display assembly off the computer base.
    • Lift and remove the display assembly off the computer base.
  8. Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base. Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
  9. Route the Mini-Card antenna cables through the slot on the computer base.
    • Route the Mini-Card antenna cables through the slot on the computer base.
  10. Connect the display cable and the camera cable to their connectors on the system board.
    • Connect the display cable and the camera cable to their connectors on the system board.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 4
Todo El Tiempo: 37
