Saltar al contenido principal
Dell Inspiron 13z 5323 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • First flip the device over, so the bottom is facing you. Then you will remove the highlighted screw.
  2. Dell Inspiron 13z 5323 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 13z 5323 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 13z 5323 Keyboard Replacement: paso 2, imagen 3 de 3
    • Flip over the laptop and open it so that the screen is facing you.
    • At the top side of the Keyboard closest to the screen you will find 2 inset plastic clips. The clips are shown here in red. Using the flat and of the metal prying tool bend the clips in and at the same time lift the keyboard up.
    • Their is a ribbon connector still attached to the bottom of the keyboard. You should be careful not to damage this cable.
  3. Dell Inspiron 13z 5323 Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron 13z 5323 Keyboard Replacement: paso 3, imagen 2 de 2
    • The ribbon connector seen in yellow can be removed by flipping up the plastic hinge clamp with a thin plastic pry lever
Conclusión
Chase Hussey
Miembro Desde 03/08/17
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 367
