Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Disconnect the hard-drive cable connector from the hard-drive assembly. Disconnect the hard-drive cable connector from the hard-drive assembly.
    • Disconnect the hard-drive cable connector from the hard-drive assembly.
  3. Lift the hard-drive assembly  away from the computer base.
    • Lift the hard-drive assembly away from the computer base.
  4. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Lift the hard-drive bracket off the hard drive. Lift the hard-drive bracket off the hard drive.
    • Lift the hard-drive bracket off the hard drive.
  7. Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  8. Replace the screws that secure the hard-drive bracket to the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  9. Connect the hard-drive cable connector to the hard-drive assembly. Connect the hard-drive cable connector to the hard-drive assembly.
    • Connect the hard-drive cable connector to the hard-drive assembly.
  10. Align the screw holes on the hard-drive assembly with the screw holes on the  computer base.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 83
