Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the  steps in "Before You Begin". Pull the pull-tab to disconnect the display cable from the system-board connector.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Pull the pull-tab to disconnect the display cable from the system-board connector.
  2. Remove the screws that secure the display assembly to the computer base.
    • Remove the screws that secure the display assembly to the computer base.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Lift the display assembly off the computer base.
    • Lift the display assembly off the computer base.
  5. Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base. Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
  6. Connect the display cable to the system-board connector.
    • Connect the display cable to the system-board connector.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 36
