Saltar al contenido principal
Dell Inspiron 13z 5323 Battery Replacement
Qué necesitas
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 2, imagen 3 de 3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: paso 3, imagen 1 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 3, imagen 2 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 3, imagen 3 de 3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: paso 4, imagen 1 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 4, imagen 2 de 3 Dell Inspiron 13z 5323 Battery Replacement: paso 4, imagen 3 de 3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Conclusión
Chase Hussey
Miembro Desde 03/08/17
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 876
