Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard drive assembly to the computer base.
  2. Slide the hard drive assembly to disconnect it from the system board connector.
    • Slide the hard drive assembly to disconnect it from the system board connector.
  3. Pull the black pull-tab and lift the hard drive assembly out of the computer base.
    • Pull the black pull-tab and lift the hard drive assembly out of the computer base.
  4. Remove the four screws that secure the hard drive to the hard drive cage.
    • Remove the four screws that secure the hard drive to the hard drive cage.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Slide the hard drive out of the hard drive cage.
    • Slide the hard drive out of the hard drive cage.
  7. Slide the NEW hard drive into the hard drive cage. Slide the NEW hard drive into the hard drive cage.
    • Slide the NEW hard drive into the hard drive cage.
  8. Replace the four screws that secure the hard drive to the hard drive cage.
    • Replace the four screws that secure the hard drive to the hard drive cage.
  9. Place the hard drive assembly in the computer base.
    • Place the hard drive assembly in the computer base.
  10. Slide and connect the hard drive assembly to the system board connector.
    • Slide and connect the hard drive assembly to the system board connector.
  11. Replace the four screws that secure the hard drive assembly to the computer base.
    • Replace the four screws that secure the hard drive assembly to the computer base.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 48
