Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se requieren partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Disconnect the display cable and the camera cable from their respective system board connectors.
  2. Remove the six screws (three on each side) that secure the display assembly to the computer base.
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  3. Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    • Lift the display assembly off the computer.
  5. Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Route the Mini-Card antenna cables through the routing guides.
  6. Connect the display cable and the camera cable to their respective system board connectors.
    • Connect the display cable and the camera cable to their respective system board connectors.
Linea de Meta
Terrence15
Miembro Desde 18/12/17
70,577 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 31
