Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. Follow the instructions in Before Working Inside Your Computer.
  2. Lift the cover off the computer and set it aside.
    • Lift the cover off the computer and set it aside.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
    • Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
  5. NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
  6. Replace the cover and tighten the screws.
    • Replace the cover and tighten the screws.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,933 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 241
