Saltar al contenido principal
Dell Inspiron 13-7373 Daughterboard Replacement
Qué necesitas
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: paso 1, imagen 1 de 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: paso 1, imagen 2 de 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: paso 2, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: paso 3, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: paso 4, imagen 1 de 1
    • Remove the daughterboard.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
81,782 Reputación
200 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 297
